I’m currently testing/using a RB2011iL-RM and I’m looking into buying 2 firewall’s for datacenter rack.
I do know that I can’t setup a firewall cluster at the moment, so it will be something active /passive that I plug-over the cables when needed. I’m also considering to replace my current 24p cisco switch.
I wonder if the Switches / http://routerboard.com/CRS125-24G-1S-RM can do the same firewalling as the / http://routerboard.com/RB2011UiAS-RM
If that is the case, then I can just buy 2 24port switches instead of 2 firewalls and 2 switches.
