Hi, we have peer to peer blocking enabled on our Mikrotik system but have recently seen that there is one peer to peer program that our system does not block, called: DC++. Does anyone know of a way to block this program?
mikrotik is able to block DC and DC++ successfully, it has been tested. maybe your configuration is not correct ?
Ok, I suppose that is probably the case then but can you maybe please tell me how to set it up correctly in that case? Thanx.
