Question regarding branding
I have some questions about the branding maker.
  1. Is there any good documenation about branding other than the poor one from the branding maker?
  2. What does the toplogo.jpg in the webcfg folder actually change. In the poor describtion it says the web-config logo. The only web-config logo I know is the one in webfig (top right corner), but that doesn’t get changed.
  3. Is there a possibility to change the master.css from the webfig.
  4. What can actually change all with the branding maker regarding the file upload.
    I know
    *) index2.html (start page of the router)
    *) images which are used in index2.html
    webcfg/
    *)style.css (effects on cfg interface)
    skins/
    *)default.json (for webfig)
    hotspot/
So what else?
Regards,
Horfic
  1. What does the toplogo.jpg in the webcfg folder actually change. In the poor describtion it says the web-config logo. The only web-config logo I know is the one in webfig (top right corner), but that doesn’t get changed.
This file changes the logo that appears in the web acces of the Dude:
I’m trying to find this file but I can’t. Where did you found it? Thanks
in older versions, before webfig was released, the same file was used also in the Webbox (grandfather of Webfig)
