Question regarding PPP session
I have set up PPP server, and I can log in using windows XP dialer.
I can even ping the router board.
The problem is, that the ping request is going “as is”, without PPP header.
I have sniffer captures of a live internet connection ( without router board )using PPP connection, and the ping packets have ~6 bytes of PPP header.
How can I set the same in RouterBoard?
Thanks,
Mark.
Guys,
Any help will be much appriciated.
How can I set PPP to have all the traffic going for this session?
Currently pings in the PPP session are sent without PPP header.
Thanks,
Mark.
hi ;
could you provide futher information about what you did to your network ?
what devices you are using ?
and the ip’s
will try to help you .
with best regards to you .
