I work at a WISP and I am routing the network that is currently in bridge mode.
I have available a /22 network and I managed to aggregate each POP with appropiate network size using best pratices. Each POP have the required network size, like /25, /26, etc depending on quantity of costumers and expected growth rate. Please see the picture below:
All routers and costumers have public addresses (I kept wireless equipment using private addresses).
My question is: When configuring each router’s OSPF, should I configure the “Networks” using each POP’s network’s (/25, /26, etc) or I can use the entire aggregated network (/22) on all routers?
Using the exact mask length will work and using an aggregate will work. However, it’s considered a best practice to only allow the specific mask you need advertised to keep from trying to form neighbors on a misconfigured interface, or advertising a subnet inadvertently.
I was thinking about a problem I could have migrating from bridge to OSPF… please take a look at the topology example I posted in my original post.
All those POPs have Mikrotik Routerboards, where I will apply OSPF. But they currently have all ports attached to a bridge (because currently my network runs on bridge).
If I start to configure OSPF before removing the interfaces from the bridge, all routerboards will be neighbors with each other… right? Do I have to configure the firewall on each routerboard to not forward OSPF discovery packets? Or this will not be an issue?
