Hello everyone,
Sorry in advance for stupid question (newbie here):
Is it possible to manually set latitude/longitude values?
I have hAP router with gps package installed.
I find this topic http://forum.mikrotik.com/t/ltap-mini-gps-useless-without-antenna/121077/1 but stuck on step disabling console, because (I assume) there is no any port.
[admin@MikroTik] /system> console print
Flags: X - disabled, U - used, F - free
# PORT TERM
So currently don’t know what to do and does it actually possible to set lat/lon.
Thanks in advance and some info which may help.
[admin@MikroTik] /system> routerboard print
routerboard: yes
board-name: hAP
model: 951Ui-2nD
serial-number: 9250085235DC
firmware-type: qca9531L
factory-firmware: 3.41
current-firmware: 3.41
upgrade-firmware: 6.43.12
[admin@MikroTik] /system> package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-mipsbe 6.43.12
1 system 6.43.12
2 X ipv6 6.43.12
3 wireless 6.43.12
4 hotspot 6.43.12
5 dhcp 6.43.12
6 mpls 6.43.12
7 routing 6.43.12
8 ppp 6.43.12
9 security 6.43.12
10 advanced-tools 6.43.12
11 gps 6.43.12
[admin@MikroTik] /system> gps print
enabled: yes
port: *FFFFFFFF
channel: 0
init-string:
set-system-time: no
[admin@MikroTik] /system> gps monitor
date-and-time: nov/30/1999 00:00:00
latitude: none
longitude: none
altitude: none
speed: none
destination-bearing: none
true-bearing: none
magnetic-bearing: none
valid: no
satellites: 0
fix-quality: 0
horizontal-dilution: 0
[admin@MikroTik] /system> gps set latitude=50.022559
expected end of command (line 1 column 9)
