Question using Mesh WDS as a dynamic hotspot Wifi repeater.
I’ve set up a mesh workbench network using multiple RB411ARs with ros 5.5 following this wiki:
http://wiki.mikrotik.com/wiki/Mesh_wds
I have a gateway to the internet handing out DHCP across the mesh. This will be a hotspot at a later date.
When I’m patched into the ether port of any of the RB411ARs I receive DHCP and connect to the internet without issues.
When I’m registered to the wlan port of any of the RB411ARs I receive DHCP yet cannot connect beyond the first RB411.
Is this correct operation? Will I require a second AP at each RB411AR site to connect to the internet using client wlan enabled equipment? Have I simply missed something?
Sounds like a routing problem to me. Your gateway probably does not have a route to your WIFI clients ip.
