Hi, what is the purpose of the the small box shown in the photo?. What is the benifit of enabling it?
Thanks alot
the [!] checkbox means “not”.
ie. if you enter the IP “1.1.1.1” and then check [!], it will mean “all addresses except 1.1.1.1”
That is a greate option, thanks again. ![]()
