Questions about Mikrotik SXT lite5
Hi!
Now i have got a two Mikrotik SXT lite5!
I wanna install them properly.
Inside the cover we can see the ground screw. Where should be connect it: to the mast or to the power supply/switch/pc chassis?
How to protect the device from the rain or snow? I wanna desgise the device from the thiefs too… May I use a plastic bag cover?
Silence :smiley:
Next question.
Which type (specification) of power connector used in PoE injector?
I bought the plug in electronic shop, but it provide not very well connection unlike the plug in the power supply which is very good.
There is grounding video on the product pages. http://routerboard.com/RBSXTG2HnD see it. There is big ideology discussion about the grounding. You should do it because it is suggested by manufacturer but I have never done it with no negative effect. Use 5.5mm /2.1mm jack. You can use the plastic bag over the device. Just take care about the temperature in a hot summer day.
a good article about grounding
http://forum.netonix.com/viewtopic.php?f=30&t=188
