Hello. My router is RB2011UiAS, so no serial port available.
- How can I know which bootloader is currently in use(main or backup)?
- Can I downgrade the bootloader, or overwrite it with the same version?
- If I’m currently using the backup bootloader, and I issue a upgrade command, will the upgrade go to the main or backup bootloader?
- Can I copy the backup bootloader to the main one and overwrite it?
Thanks!
