Questions about RouterOS v5.26 and winbox
After founding a bug that affects dns servers field input into winbox, I was wondering 2 things about winbox in routerOS 5.26:
-how to import/export configuration file via winbox (batch router configuration);
-is there a way to avoid router’s connection to a specific MAC address (via winbox);
-how to automatically set date & time?
thanks in advance
for your last question,
configure NTP client in the router and select Time zone.
You are done!!!
login in to router using winbox
click on main menu ===> System
Click On ===>SNTP client or NTP Client
a New window will appear.
Tick on Enable
Select Mode : Unicast
type Primary NTP Server as : 133.27.94.149 ==>> click on OK
Now again click on ==>System ==>> Clock
Select Time zone Name ====> click OK
DONE!!!
thanks @navshad
but the most important question is:
is there a way to avoid router’s connection to a specific MAC address??
even via terminal!
