I am the new beginner for RB951G-2HnD. And, I have some questions about wireless:
- How to adjust the power of the wireless (High, Mid, Low)?
- How to schedule on and off time for wireless?
Thank you,
Thank you,
Have you read the wiki? Have you searched the forum? Try it first.
TX power: Have a look at “all-rates-fixed” here
For the on/off schedule look at the Scheduler Manual.
And then add
/interface wireless disable wlan1
and
/interface wireless enable wlan1
at the appropriate scheduler entries.
(First look up the correct name for you w/l interface).
Cheers
-Chris
Thanks, Chris.
Can you show the complete script for setting on and off the wireless interface?
It is for me not clear on the wiki
Many thanks
/system scheduler
add disabled=no interval=1d name=wlan-off on-event=“/interface wireless disable wlan1” policy=ftp,winbox,api start-date=apr/30/2014 start-time=18:00:00
add disabled=no interval=1d name=wlan-on on-event=“/interface wireless enable wlan1” policy=ftp,winbox,api start-date=may/1/2014 start-time=9:00:00This will shut down the WiFi tonight at 18:00 (start-time=18:00:00) and bring it back tomorrow morning at 9:00 (start-time=9:00:00)
From now on daily (interval=1d)
Good luck.
-Chris
Thanks Chris +1
