Couple questions on netpower lite 8P:
Does the product code ending in OUT mean it’s outdoor version of identical CSS610-8P-2S+IN indoor version?
Can anyone confirm the ports can be configured to for POE auto, on, or off. I have some 48V passive devices that would need hte “on” setting and its not clear if this device or switch OS lite allows it.
Anyone have a link to the green terminal connectors that take you from small screw terminal to the green keyed power port connection that look like Phoenix contact type connections?
Also – what 48 or 50 or 54 volt power brick would you use with this to get up to the full POE budget it offers. I was thinking 54 volt or so would be nice to help with voltage drop.
Can you recommend an outdoor UV proof cable (direct bury capable nice to have) that is 2 or 3 conductor. I might use 4 conductors (two pairs) combined for each + and return of outdoor CAT5E cable but was thinking thats equivalent to 18 guage and could probably do 16, 14, or even 12 gauge stranded multi conductor wire. Wondering what makes sense for the terminals at the switch and also to get it wired into a decent power supply – maybe a meanwell w/ screw terminals at the supply end.
Thanks for any insight! It seems this switch is rather new — the UPS battery backup feature at 24 volts is really slick also.
