I’m reading CCR1036 Test setup in https://wiki.mikrotik.com/wiki/Manual:Performance_Testing_with_Traffic_Generator#Defaults.2C_routing.
- Where does pt0 comes from in bellow code ? Should this line be simply removed ?
/tool traffic-generator stream
add id=0 mbps=700 name=str0 packet-size=60 tx-template=pt0
Could you please print IP routes in either DUT and TR2 ?
How can you make sure generated traffic goes from TR2 through DUT and not directly “flowing inside TR2” ? -
Is it necessary to both generate from ether1 to ether2 and vice versa or is it possible to focus, as a first step, on a single flow going from ether1 to ether2 without generating traffic in the opposite direction ?
Whatever the answer, could it be possible to explicitly include in the Wiki page ?
Best regards
