i got an crs125-24g which i believe has somewhat poor performance currently. I am not sure if its either my config or the hardware limiting the thing i want to archive.
Heres what i want to do:
Have 2 VLANs both with their own dhcp server and pool.
Share internet traffic between those 2 vlans in a way that if:
- vlan1 is idle vlan2 gets full speed and vice versa
if vlan1 and vlan2 need full power, bandwith is shared equally
I tried to archive that with both simple queues and a queue tree with firewall mangle rules.
My observation is that both rulesets do not get full speed because the cpu is hitting solid 90-100%.
My ISP Bandwidth: 150mbit (tested and verified on the modem itself)
Max with simple queues: 90mbit
Max with queue tree: 70mbit
I tried both regular website speed tests and well seeded torrent downloads.
Questions:
I heard that you can reduce cpu load if you do not config the vlan’s as interfaces and use the switch cpu exclusively. How would i build separated dhcp pools in that case?
Here is my setup:
add name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
set [ find default-name=ether6 ] master-port=ether2-master
set [ find default-name=ether7 ] master-port=ether2-master
set [ find default-name=ether8 ] master-port=ether2-master
set [ find default-name=ether9 ] master-port=ether2-master
set [ find default-name=ether10 ] master-port=ether2-master
set [ find default-name=ether11 ] master-port=ether2-master
set [ find default-name=ether12 ] master-port=ether2-master
set [ find default-name=ether13 ] master-port=ether2-master
set [ find default-name=ether14 ] master-port=ether2-master
set [ find default-name=ether15 ] master-port=ether2-master
set [ find default-name=ether16 ] master-port=ether2-master
set [ find default-name=ether17 ] master-port=ether2-master
set [ find default-name=ether18 ] master-port=ether2-master
set [ find default-name=ether19 ] master-port=ether2-master
set [ find default-name=ether20 ] master-port=ether2-master
set [ find default-name=ether21 ] master-port=ether2-master
set [ find default-name=ether22 ] master-port=ether2-master
set [ find default-name=ether23 ] master-port=ether2-master
set [ find default-name=ether24 ] master-port=ether2-master
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add comment=Erdgeschoss interface=ether2-master name=vlan10_eg vlan-id=10
add comment=Obergeschoss interface=ether2-master name=vlan20_og vlan-id=20
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="ether1-gateway,et\
her10,ether11,ether12,ether13,ether14,ether15,ether16,ether17,ether18,ethe\
r19,ether20,ether21,ether22,ether23,ether24" forward-unknown-vlan=no
add name=pool_eg ranges=192.168.10.10-192.168.10.254
add name=pool_og ranges=192.168.20.10-192.168.20.254
add address-pool=pool_eg disabled=no interface=vlan10_eg name=dhcp_eg
add address-pool=pool_og disabled=no interface=vlan20_og name=dhcp_og
/queue simple
add disabled=yes dst=ether1-gateway limit-at=5M/50M max-limit=10M/150M name=\
eg target=192.168.10.0/24
/queue type
add kind=pcq name=pcq-download pcq-classifier=dst-address
add kind=pcq name=pcq-upload pcq-classifier=src-address
add kind=pfifo name=default-long pfifo-limit=100
/queue interface
set ether1-gateway queue=ethernet-default
set ether2-master queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
set ether6 queue=ethernet-default
set ether7 queue=ethernet-default
set ether8 queue=ethernet-default
set ether9 queue=ethernet-default
set ether10 queue=ethernet-default
set ether11 queue=ethernet-default
set ether12 queue=ethernet-default
set ether13 queue=ethernet-default
set ether14 queue=ethernet-default
set ether15 queue=ethernet-default
set ether16 queue=ethernet-default
set ether17 queue=ethernet-default
set ether18 queue=ethernet-default
set ether19 queue=ethernet-default
set ether20 queue=ethernet-default
set ether21 queue=ethernet-default
set ether22 queue=ethernet-default
set ether23 queue=ethernet-default
set ether24 queue=ethernet-default
set sfp1 queue=ethernet-default
/queue simple
og queue=ethernet-default/ethernet-default target=192.168.20.0/24
/queue tree
add disabled=yes max-limit=170M name=gateway-down parent=ether2-master queue=\
default
add disabled=yes limit-at=50M max-limit=170M name=og-down packet-mark=\
og_packet parent=gateway-down queue=ethernet-default
add disabled=yes limit-at=50M max-limit=150M name=eg-down packet-mark=\
eg_packet parent=gateway-down queue=ethernet-default
add disabled=yes max-limit=10M name=gateway-up parent=ether1-gateway queue=\
default
add disabled=yes limit-at=5M max-limit=10M name=eg-up packet-mark=eg_packet \
parent=gateway-up queue=ethernet-default
add disabled=yes limit-at=5M max-limit=10M name=og-up packet-mark=og_packet \
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu vlan-id=20
add tagged-ports=switch1-cpu vlan-id=10
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=20 ports="ether24,ether22,ether20,ether18,\
ether16,ether14,ether12,ether10,switch1-cpu"
add customer-vid=0 new-customer-vid=10 ports="ether23,ether21,ether19,ether17,\
ether15,ether13,ether11,ether9,switch1-cpu"
ether16,ether14,ether12,ether10,ether8,ether6,ether4,ether2-master,switch1\
-cpu"
ether15,ether13,ether11,ether9,ether7,ether5,ether3,switch1-cpu"
add ports="ether10,ether12,ether14,ether16,ether18,ether20,ether22,ether24,swi\
tch1-cpu" vlan-id=20
add ports="ether9,ether11,ether13,ether15,ether17,ether19,ether21,ether23,swit\
ch1-cpu" vlan-id=10
add address=192.168.10.1/24 interface=vlan10_eg network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20_og network=192.168.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.20.20 client-id=1:9c:c7:a6:3c:e9:92 mac-address=\
9C:C7:A6:3C:E9:92 server=dhcp_og
add address=192.168.10.0/32 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.10.1 \
netmask=24
add address=192.168.10.0/24 dns-server=9.9.9.9,8.8.8.8,8.8.4.4 gateway=\
192.168.10.1
add address=192.168.20.0/32 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1 \
netmask=24
add address=192.168.20.0/24 dns-server=9.9.9.9,8.8.8.8,8.8.4.4 gateway=\
192.168.20.1
add address=192.192.192.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.192.192.1
set allow-remote-requests=yes servers=9.9.9.9,8.8.8.8,8.8.4.4
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=accept chain=forward connection-state=established,related
add action=accept chain=input comment="accept established related" \
connection-state=established,related disabled=yes
add action=drop chain=input comment="drop invalid connections" \
connection-state=invalid disabled=yes
add action=drop chain=forward connection-state=invalid disabled=yes
add action=accept chain=input comment="allow icmp" disabled=yes protocol=\
icmp
add action=accept chain=input disabled=yes in-interface=!ether1-gateway \
in-interface-list=all src-address=192.168.20.0/24
in-interface-list=all src-address=192.168.10.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.20.0/24 \
add action=drop chain=forward disabled=yes dst-address=192.168.10.0/24 \
add action=drop chain=forward disabled=yes src-address=0.0.0.0/8
add action=drop chain=forward disabled=yes dst-address=0.0.0.0/8
add action=drop chain=forward disabled=yes src-address=127.0.0.0/8
add action=drop chain=forward disabled=yes dst-address=127.0.0.0/8
add action=drop chain=forward disabled=yes src-address=224.0.0.0/3
add action=drop chain=forward disabled=yes dst-address=224.0.0.0/3
/ip firewall mangle
add action=mark-connection chain=prerouting disabled=yes new-connection-mark=\
og_con passthrough=yes src-address=192.168.20.0/24
eg_con passthrough=yes src-address=192.168.10.0/24
add action=mark-packet chain=forward connection-mark=og_con disabled=yes \
new-packet-mark=og_packet passthrough=yes
add action=mark-packet chain=forward connection-mark=eg_con disabled=yes \
new-packet-mark=eg_packet passthrough=yes
add action=masquerade chain=srcnat out-interface=ether1-gateway
add disabled=yes distance=1 gateway=ether1-gateway
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=ether1-gateway type=external
/lcd
set backlight-timeout=10m default-screen=informative-slideshow
/system clock
/system watchdog
set watchdog-timer=no
