Queue Capsman
Hello, when i use capsman forwading why on the queue tree the traffic is doubled?
Can you please provide more information?
Do you have some screenshot / cli output which shows this issue?
Which version of RouterOS do you use?
Which version of CAPsMan are you using?
Do you have some screenshot / cli output which shows this issue? Not
Which version of RouterOS do you use? version 7.15.3
Which version of CAPsMan are you using? how i can knowing this?
Get the export:
/export file=anynameyoulike
Remove serial and any other private info, post in between code tags by using the </> button.
