queue in pppoe client
Hi
this is possible to do a simple queue in client cpe (pppoe client) for the priority of the voip?
the velocities in download and upload is managed by a radius and not by the queue..
i want only reserved for example 100K upload for the voip calling..
nothing else…
thank you
Yes, there are a couple of things that you can do. In earlier versions of RouterOS, Simple queues had priority over HTB, but now that is not true. So you can create an HTB tree to compliment the simple queue. You can also use metarouter, which has been a long time work around, to handle that type of scenario.
