I have a small network that uses capsmanv2.
I am advertising two ssid (main and guest).
Both ssid are using distinct datapath (they are also using a different bridge).
Now, when I create my tree and want to deal with outbound it’s easy as I can just select my wan interface as the parent.
However, when creating the inbound policy, if I select the main bridge, traffic flowing through guest will not be processed in the queue (and vice versa).
how would you guys suggest I set things up in order to have both my bridge managed via the same queue tree.
thanks
Simon
