Queue Not Limiting Download
With “Use IP Firewall” enabled, I often run a simple queue on a port. Periodically, that queue will only limit upload, not download.
I just moved a port that was running correctly (with a queue applied to that port) from one bridge to another. Now that queue only works on upload, not download.
I created a new queue with the same parameters, but it still does not work correctly.
Is there a specific order in which to add a port to a bridge and then add a queue?
Thank you,
Chris
Not sure how the rest of your config works… Here’s an example that I threw together where I can limit the download and upload of a specific IP behind my Mikrotik using simple queues.
 0 XI  name="Test" target=10.10.25.66/32 parent=none packet-marks="" priority=8/8 queue=default-small/default-small
      limit-at=0/0 max-limit=512k/512k burst-limit=768k/768k burst-threshold=768k/768k burst-time=10s/10s
I’m limiting the speed on a port-by-port basis. I’ve generally had trouble with port speed queues, but I thought I had the issue resolved. It has been working correctly for months. All I changed was the bridge the port was connected to.
This is a queue that was functioning:
/queue simple
add limit-at=10M/10M max-limit=10100k/10100k name=TH-5M target=\
    ether2-TH-Service
The only connection to this port is through a bridge. I changed the bridge port, and now the download is unlimited on the queue, even though the queue has not changed.
I’ve tried re-entering the queue, but it does not help.
BUG?
I got the queue to work. This is on an RB750 running bugfix v6.32.4.
This does not work, and only limits upload:
/queue simple
add max-limit=10100k/10100k name=queue1 target=ether2
This does work, and limits both upload and download correctly:
/queue simple
add max-limit=10100k/10100k name=queue1 target=ether2,0.0.0.0/0
If I check in WinBox, the queue now shows two targets. BUT, in the CLI, printing the queues and the configuration export only shows ether2. Is there something I’m missing here?
Have you tried with bridge ip firewall disabled?
The queue does not function at all with “Use IP Firewall” disabled.
Have you tried to remove the port from the bridge?
I use a simple que
/queue simple
add max-limit=1M/5M name=queue1 target=ether1-gateway
I have not. I need the bridge for my system to function correctly (specifically with IP usage, I cannot dedicate a /30 to each port I need to limit).
Disable Bridge
Interfaces> “Select Ether Port” >General
Master Port > “Select Port to make master” to bridge ports you want to bridge this way
That’s how I sorted the Queue problem on my metal
Hi, Could you find the solution?
Same bug here:
Queue over ether3 only controls upload:
