[admin@MikroTik] /queue simple> print
0 name="queue1" target=ether1-gateway parent=none packet-marks="" priority=8/8 queue=default-small/default-small limit-at=0/0 max-limit=15M/15M burst-limit=0/0 burst-threshold=0/0
burst-time=0s/0s
Now, I am starting to send UDP traffic with iPerf from the LAN to the WAN:
iperf -c 10.0.0.10 -u -b 200M -t 1200
We can see that everything is OK and working properly :
Now, I am sending TCP traffic with iPerf :
iperf -c 10.0.0.10 -t 1200
And I can see that no limitation is applied :
I really don’t know, am I doing something wrong ? I tried the same configuration on a RB951G-2HnD, and this was working fine.
Do you get the same results if you create manually TCP traffic (downloading files…)? Are you using latest rOS ? You should check if the configuration and test conditions are exactly the same on both devices.
If you still see queues performance differences, you should write to Mikrotik support, with included supout files: http://www.mikrotik.com/support.html
Just did what you suggested : reset factory on both routeur. Last update on both router, just pushed the /queue simple add targer ether1-gateway max-limit=5M/5M : UDP is rate-limited, but not TCP
I downgraded to 6.24, did the exact same thing and … TCP is rate-limited.
Definitely a bug there.
At least, i’ll be able to do what i want now, thanks for you help
