Queue simple not working...
I’ve set up my rb2011 with ether-1 as gateway interface,leeds to isp
wlan1 is for my wireless laptops,set it up as seperate network (192.168.5.0/24)
I’ve created a virtual AP(wlan2) for my guests,gave it seperate network (192.168.6.0/24).
DHCP and etc works fine,everyone can get to the internet.
I am trying to limit all clients for the wlan2 to use certain bandwidth. I want 5M to be available for all the clients in my wlan2,no more. If there is one client, he can get 5M. If there are two, they can share it equally, and so on.
I’ve tried several configurations with queues,simple, tree queue,queue types, but none of these worked…
Can someone help please?
Thnks
This probably will help you..
Create a new simply queue, as my picture bellow.. In interface you can select interface (as my scenario) or enter your guest network pool 192.168.6.0/24. That will limit 5M DL and 5M UL for all your clients that is connected to guest wifi. I hope so its more easy for you now. :smiley:
Thnks for the reply but unfortunately this is not working!
What am doing wrong?
Should I remove all the default configuration at the beginning? I am testing it with several speedtests…
Start with default configuration. For me before posted config is working great. You can follow also my tutorial how to do that you want. Only start with default config. And follow my tutorial.
http://forum.mikrotikmacedonia.com/index.php/topic,43.0.html
I’ve started with default conf and only the queue, after arranging the necessary IP’s to the interfaces,dhcp server and default gateway.Nothing else!
I am attaching the export here.
Maybe you see something I cannot see!
Thnks
[admin@MikroTik] > export
# sep/21/2015 10:55:05 by RouterOS 6.32.1
# software id = WD3W-Q6N6
add admin-mac=00:0C:42:8D:50:B5 auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
    ether5-slave-local
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=\
    ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=\
    ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=\
    ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=\
    ether10-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed \
    mode=dynamic-keys name=profile1 wpa-pre-shared-key=xxxxxx123456 \
    wpa2-pre-shared-key=xxxxxx123456
    mode=dynamic-keys name=profile2 wpa-pre-shared-key=xxxxx54321 \
    wpa2-pre-shared-key=xxxxxx654321
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    disabled=no distance=indoors frequency=auto mode=ap-bridge \
    security-profile=profile1 ssid=frena-intranet wireless-protocol=\
    802.11
add disabled=no mac-address=02:0C:42:8D:50:BE master-interface=wlan1 \
    name=wlan2 security-profile=profile2 ssid=frena-guest wps-mode=\
    disabled
add name=poolwlan1 ranges=192.168.5.10-192.168.5.250
add name=poolwlan2 ranges=192.168.6.10-192.168.6.250
add address-pool=default-dhcp disabled=no interface=bridge-local name=\
    default
add address-pool=poolwlan1 disabled=no interface=wlan1 lease-time=3h \
    name=serverwlan1
add address-pool=poolwlan2 disabled=no interface=wlan2 lease-time=3h \
    name=serverwlan2
/queue simple
add max-limit=2M/2M name=skata target=wlan2
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=sfp1
add bridge=bridge-local disabled=yes interface=wlan1
/interface bridge settings
set use-ip-firewall=yes
add address=192.168.88.1/24 comment="default configuration" interface=\
    bridge-local network=192.168.88.0
add address=192.168.1.52/24 interface=ether1-gateway network=192.168.1.0
add address=192.168.5.1/24 interface=wlan1 network=192.168.5.0
add address=192.168.6.1/24 interface=wlan2 network=192.168.6.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid \
    disabled=no interface=ether1-gateway
add address=192.168.5.0/24 dns-server=195.170.0.1 gateway=192.168.5.1 \
    netmask=24
add address=192.168.6.0/24 dns-server=195.170.0.1 gateway=192.168.6.1 \
    netmask=24
add address=192.168.88.0/24 comment="default configuration" gateway=\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related
add action=drop chain=input comment="default configuration" in-interface=\
    ether1-gateway
add action=fasttrack-connection chain=forward comment=\
    "default configuration" connection-state=established,related
add chain=forward comment="default configuration" connection-state=\
    established,related
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
    connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway
add distance=1 gateway=192.168.1.4
/system clock
set time-zone-name=Europe/Athens
/system package update
set channel=current
/system routerboard settings
set boot-device=flash-boot
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ether10-slave-local
add interface=sfp1
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=sfp1
add interface=wlan1
/tool romon port
Can you send me ip cloud dns and admin user/pass to PM so i can configure it remotely ??
ok!
Are you testing by connecting to the wlan2 AP?
also try to set your limit @ on the advanced page
as for the bandwidth sharing once this works we move to the next phase
I basically had this issue for years i solved it by creating a parent queue an the users join the queues as slaves
Could you please show us the way through parent queues?
Thnks
use 192.168.6.0/24 as target
Very strange…
I think MT programmers should have a look on that.
With the same EXACT configuration simple queue is working on 6.20, but it’s NOT working at 6.30.x…
Hello xtrgeo.
I have the same problem too.
did you solve it?
no there is no solution yet.Still. using 6.20
If someone has any update on that,please notify!
In 6.33.3, I solved by disabling the rule “fasttrack” in the firewall.
Inviato dal mio Nexus 7 utilizzando Tapatalk
The same solution works for me. Thanks mate.
