Hi all,
Since moving to RouterOS 6.x I’ve not been able to setup multiple parent shapers in /queue simple.
for example if i have a parent rule defining a max-limit of 100M/100M with a target of 0.0.0.0/0 with a child shaper pointing to that it works fine.
But if i introduce another parent shaper with a max-limit of 50M/50M below that with another child shaper it seems to be ignored, if you move said rules above the rules made above for the 100M parent shaper then they are used instead and the others are ignored.
Is there a specific method of getting multiple parent shapers working without one taking precedence?
