queue simple
hi all
in documentatios is written that setting max-limit=0/0 means not limitation so can I add a queue like that:
 0    name="user1" dst-address=A.B.C.D/32 interface=wireless
      parent=none direction=both priority=8 queue=default-small/default-small
      limit-at=0/0 max-limit=0/0 total-queue=default-small
for every user that I have connected do AP for statistics purposes shown on webif (tool/graphing/queue)?
is it really for example 30 queues like above don’t affect data traffic ?
how simple queue is implemented in MT? to which queue type it can by compared (FIFO, TBF, SFQ etc) ??
and last question. if I have set /queue interface type to SFQ, is it consider before or after added simple queue’s? and if before .. how it is done. SFQ is classles
and really last question :slight_smile:
Per Connection Queuing (PCQ) is other name for ESFQ ??
thx for replays and sorry for my bad english.
