Queue support intefaces wise
Thanks for the supporting people and i need asmall support, my network is
ether1 ether 2
Ether 1 is the internet port and natting to ether2 and simple queues for the PC’s (20nos) 256Kbps each
My requirement is ether 1 is having the speed of 2Mbps internet and i need to share only 1.5Mbps to ether2 as well as simple queues also 256Kbps each
Please help me in getting solution for the above i need 512Kbps before the mikrotik and dont want to be allowed all those bandwidth by ether2
Thanks,
Sathish
Stop using simple queues and use PCQ instead. The wiki has examples on how you can slice up 256kbps per user with a total rate limit of 1.5mbps for all those queues.
Thanks very much i will get back to you after done
