Hi guys, how are you?
I’m here again. I would like to share my queue tree implementation, but I don’t know if the implementation is correct. Can someone help me?
I have the following scenario:
with this setup:
IP Firewall/Mangle
add action=mark-routing chain=prerouting dst-address=192.168.1.0/24 new-routing-mark=“Route to router C” passthrough=no
add action=mark-connection chain=prerouting comment=IAX2 dst-port=4569 new-connection-mark=IAX2 protocol=udp
add action=mark-packet chain=prerouting connection-mark=IAX2 new-packet-mark=IAX2
add action=mark-routing chain=prerouting connection-mark=IAX2 new-routing-mark=EOIP_Tunnel passthrough=no src-address-list=“Voip Network”
add action=mark-connection chain=prerouting comment=“Other Connections” new-connection-mark=Other_Conn
add action=mark-packet chain=prerouting connection-mark=Other_Conn new-packet-mark=Other_Conn
add action=mark-routing chain=prerouting connection-mark=Other_Conn new-routing-mark=EOIP_Tunnel passthrough=no src-address-list=IPAddressList_RouterA&B
Ip/Route
add comment=“Route to router C” distance=1 dst-address=192.168.1.0/24 gateway=10.10.4.2 routing-mark=“Route to router C”
add comment=“Route EOIP Tunnell” distance=1 gateway=10.10.7.1 routing-mark=EOIP_Tunnel
Queue Tree
add max-limit=4096k name=“Queue Global” parent=global priority=1 queue=default
add limit-at=512k max-limit=512k name=“Queue IAX2” packet-mark=IAX2 parent=“Queue Global” priority=2 queue=default
add limit-at=3584k max-limit=3584k name=“Queue Other Connection” packet-mark=Other_Conn parent=“Queue Global” queue=default
Is it correct? My doubt is because I use the EOIP tunnel, then I need to mark the connection, mark the packet and send the data by the EOIP.
Best Regards,
Adraino
