queue tree not working with pppoe server
I wanna set some speed limit to user in pppoe server.
The upload rule is ok, but the download run do not work
I find the problem may be the parent setting in queue tree, so it will work only selecting the current pppoe user(),
but you know there will be more user later and i can’t select more than one.
following is my export compact, and thx :slight_smile:
    [admin@MikroTik] > export compact \
# oct/26/2012 12:25:11 by RouterOS 5.21 \
# software id = BD0B-6TGV \
    add \
        name=bridge-local \
        admin-mac=D4:CA:6D:6E:96:0A \
        auto-mac=no \
        l2mtu=2290 \
        protocol-mode=rstp
/interface wireless
    set 0 \
        band=2ghz-b/g/n \
        channel-width=20/40mhz-ht-above \
        country="hong kong" \
        disabled=no \
        distance=indoors \
        ht-rxchains=0,1 \
        ht-txchains=0,1 \
        l2mtu=2290 \
        mode=ap-bridge \
        wireless-protocol=any
    set 0 \
        name=sfp1-gateway
    set 1 \
        name=ether1-gateway
    set 4 \
        name=ether4-lan
    set 6 \
        name=ether6-master-local
    set 7 \
        name=ether7-slave-local \
        master-port=ether6-master-local
    set 8 \
        name=ether8-slave-local \
    set 9 \
        name=ether9-slave-local \
    set 10 \
        name=ether10-slave-local \
/interface pppoe-client
    add \
        name=pppoe-out1 \
        add-default-route=yes \
        disabled=no \
        interface=ether1-gateway \
        password=**** \
        user=****
    set [ find default=yes ] \
        authentication-types=wpa2-psk \
        mode=dynamic-keys \
        wpa-pre-shared-key=**** \
        wpa2-pre-shared-key=****
/ip hotspot user profile
        idle-timeout=none \
        keepalive-timeout=2m
    add \
        name=Pool_Tenant \
        ranges=192.168.6.10-192.168.6.99
    add \
        name=Pool_Admin \
        ranges=192.168.20.10-192.168.20.99
    add \
        name=DHCP_Admin \
        address-pool=Pool_Admin \
        disabled=no \
        interface=bridge-local \
        lease-time=1d
/ppp profile
    set 1 \
        idle-timeout=30m \
        local-address=192.168.6.1 \
        only-one=yes \
        remote-address=Pool_Tenant
/queue type
    add \
        name=PCQ_Down \
        kind=pcq \
        pcq-classifier=dst-address \
        pcq-dst-address6-mask=64 \
        pcq-src-address6-mask=64 \
        pcq-total-limit=2500
    add \
        name=PCQ_Up \
        kind=pcq \
        pcq-classifier=src-address \
/queue tree
    add \
        name=Tree_Down \
        limit-at=1M \
        max-limit=1M \
        packet-mark=Mark_Packet \
        parent=global-in \
        queue=PCQ_Down
    add \
        name=Tree_Up \
        disabled=yes \
        limit-at=1200k \
        max-limit=1200k \
        parent=ether1-gateway \
        queue=PCQ_Up
    add \
        bridge=bridge-local \
        interface=ether2
    add \
        interface=ether3
    add \
        interface=ether4-lan
    add \
        interface=ether5
    add \
        interface=wlan1
/interface pppoe-server server
    add \
        authentication=pap,chap \
        default-profile=default-encryption \
        disabled=no \
        interface=ether6-master-local \
        one-session-per-host=yes \
        service-name=PPPoE_Server
    add \
        comment="default configuration" \
        address=192.168.88.1/24 \
        interface=wlan1
    add \
        address=192.168.1.1/24 \
    add \
        address=192.168.6.1/24 \
    add \
        address=192.168.20.1/24 \
    add \
        address=192.168.6.0/24 \
        gateway=192.168.6.1 \
        netmask=24
    add \
        address=192.168.20.0/24 \
        gateway=192.168.20.1 \
        netmask=24
    set \
        allow-remote-requests=yes \
        servers=218.102.52.81,218.102.23.77,8.8.4.4,210.87.250.13
/ip dns static
    add \
        name=router \
/ip firewall address-list
    add \
        address=192.168.6.10-192.168.6.99 \
        list=FirewallAddressList_Tenant
    add \
        chain=input \
        protocol=icmp
    add \
        chain=input \
        connection-state=established
    add \
        chain=input \
        connection-state=related
    add \
        action=drop \
        chain=input \
        in-interface=sfp1-gateway
    add \
        action=drop \
        chain=input \
        in-interface=ether1-gateway
/ip firewall mangle
    add \
        action=mark-connection \
        chain=forward \
        new-connection-mark=Mark_Connection \
        src-address=192.168.6.10-192.168.6.99
    add \
        action=mark-packet \
        chain=forward \
        new-packet-mark=Mark_Packet \
        passthrough=no
    add \
        action=masquerade \
        chain=srcnat \
        out-interface=pppoe-out1
/ip neighbor discovery
    set sfp1-gateway \
        disabled=yes
    set ether1-gateway \
        disabled=yes
    set wlan1 \
        disabled=yes
/ppp secret
    add \
        name=305 \
        password=**** \
        service=pppoe
/system clock
    set \
        time-zone-name=Asia/Hong_Kong
/system clock manual
    set \
        time-zone=+08:00
/system scheduler
    add \
        name=schedule1_DDNS \
        interval=15m \
        on-event="/tool dns-update name=connectto.myDDNS.com address=www.changeip.com key-name=alright2070 key=byst2070" \
        policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
        start-time=startup
/tool mac-server
    add \
        disabled=no \
        interface=ether2
    add \
        disabled=no \
        interface=ether3
    add \
        disabled=no \
    add \
        disabled=no \
        interface=ether5
    add \
        disabled=no \
    add \
        disabled=no \
        interface=ether7-slave-local
    add \
        disabled=no \
        interface=ether8-slave-local
    add \
        disabled=no \
        interface=ether9-slave-local
    add \
        disabled=no \
        interface=wlan1
    add \
        disabled=no \
/tool mac-server mac-winbox
        disabled=yes
    add \
        interface=ether2
    add \
        interface=ether3
    add \
    add \
        interface=ether5
    add \
    add \
    add \
    add \
    add \
        interface=wlan1
    add \
    [admin@MikroTik] >
    echo: system,error,critical login failure for user zhi from 222.219.199.28 via ssh
