Hi Guys,
We use Cacti to keep an eye on our network. We have Queue Trees setup in our CCR Routers and everything works great.
When I look at
queue tree print oid
I get a print out of all the oid’s for the queue trees.
We have SNMP enabled and we are currently graphing all the interfaces without issue, however, when I try to create a graph from the queue tree I get nothing back.
Do I have to do something specific in order to get data from the queue trees?
Thanks Guys.
Please post your /snmp configuration here.
Do you have one default gateway on your router?
We only have 1 WAN Gateway, but we have multiple LAN gateways to facilitate different devices on different L2 subnets.
If it helps, the Cacti machine which I am trying to create these graphs from is already successfully graphing all the Physical and PPPoE interfaces without any issues.
Try to run snmpwalk and snmpget from your Cacti router.
Do you get any output?
Yeah,
i can see all the physical interfaces and all the PPPoE interfaces. But that is all.
When you run snmpwalk for queue tree oid, do you get any result?
Hey,
This is the result I get.
adminuser@cactimachine ~}# snmpwalk -c -v Hostname .1.3.6.1.4.1.14988.1.1.2.2.1.7.16777232
SNMPv2-SMI::enterprises.14988.1.1.2.2.1.7.16777232 = Counter64: 69162225226
Ok, I think I may have figured out my issue.
When I created my graph I used a Gague type. I have changed it to a counter and now I see results.
However, this has lead me onto a second issue.
How do I know which OID relates to which queue?
I setup the Queue Trees via Winbox.
Below is I have written out my current queue tree layout (as shown in Winbox) and below that is the output from terminal for the queue tree OID’s. Can you tell me how I correlate the two.
Thanks.
Main Download
–Business Down
----2.5Mbps Business Down
----5Mbps Business Down
----7.5Mbps Business Down
----10Mbps Business Down
----50Mbps Business Down Main Office
–Business Symetrical Down
----2.5Mbps/2.5Mbps Business Symmetrical Down
----5Mbps/5Mbps Business Symmetrical Down
----10Mbps/10Mbps Business Symmetrical Down
----15mbps/15Mbps Business Symmetrical Down
-----20Mbps/20Mbps Business Symmetrical Down
–Home Down
----2.5Mbps Home Download
----5Mbps Home Download
----7.5Mbps Home Download
----8Mbps/3Mbps Split Download
----10Mbps Home Download
----15mbps/5Mbps Bridge Holder Download
----Default Connection Download
Main Upload
–Business Symmetrical UP
----2.5Mbps/2.5Mbps Business Symmetrical UP
----5Mbps/5Mbps Business Symmetrical UP
----10mbps/10Mbps Business Symmetrical UP
----15mbps/15Mbps Business Symmetrical UP
----20Mbps/20Mbps Business Symmetrical UP
–Business UP
----2.5Mbps Business UP
----5Mbps Business UP
----7.5Mbps Business UP
----10Mbps Business UP
----50Mbps/50Mbps Business UP Office
–Home UP
----2.5Mbps Home UP
----5Mbps Home UP
----8Mbps/3Mbps Split Upload
----10Mbps Home UP
----15Mbps/5Mbps Bridge Holder UP
----Default Connection Upload
VOIP-UPLOAD
VOIP_Download
0 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777217
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777217
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777217
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777217
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777217
1 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777219
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777219
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777219
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777219
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777219
2 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777220
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777220
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777220
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777220
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777220
3 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777221
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777221
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777221
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777221
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777221
4 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777222
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777222
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777222
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777222
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777222
5 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777223
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777223
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777223
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777223
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777223
6 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777224
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777224
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777224
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777224
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777224
7 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777225
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777225
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777225
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777225
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777225
8 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777226
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777226
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777226
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777226
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777226
9 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777227
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777227
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777227
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777227
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777227
10 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777228
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777228
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777228
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777228
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777228
11 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777229
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777229
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777229
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777229
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777229
12 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777230
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777230
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777230
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777230
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777230
13 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777231
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777231
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777231
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777231
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777231
14 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777232
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777232
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777232
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777232
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777232
15 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777233
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777233
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777233
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777233
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777233
16 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777234
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777234
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777234
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777234
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777234
17 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777235
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777235
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777235
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777235
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777235
18 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777236
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777236
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777236
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777236
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777236
19 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777247
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777247
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777247
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777247
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777247
20 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777248
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777248
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777248
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777248
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777248
21 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777249
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777249
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777249
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777249
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777249
22 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777250
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777250
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777250
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777250
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777250
23 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777251
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777251
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777251
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777251
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777251
24 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777252
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777252
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777252
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777252
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777252
25 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777253
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777253
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777253
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777253
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777253
26 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777254
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777254
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777254
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777254
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777254
27 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777255
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777255
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777255
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777255
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777255
28 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777256
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777256
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777256
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777256
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777256
29 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777257
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777257
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777257
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777257
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777257
30 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777258
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777258
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777258
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777258
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777258
31 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777271
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777271
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777271
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777271
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777271
32 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777272
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777272
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777272
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777272
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777272
33 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777273
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777273
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777273
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777273
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777273
34 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777274
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777274
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777274
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777274
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777274
35 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777275
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777275
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777275
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777275
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777275
36 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777276
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777276
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777276
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777276
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777276
37 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777277
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777277
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777277
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777277
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777277
38 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777278
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777278
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777278
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777278
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777278
39 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777279
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777279
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777279
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777279
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777279
40 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777280
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777280
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777280
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777280
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777280
41 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777281
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777281
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777281
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777281
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777281
42 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777282
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777282
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777282
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777282
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777282
43 name=.1.3.6.1.4.1.14988.1.1.2.2.1.2.16777283
packet-mark=.1.3.6.1.4.1.14988.1.1.2.2.1.3.16777283
bytes=.1.3.6.1.4.1.14988.1.1.2.2.1.7.16777283
packets=.1.3.6.1.4.1.14988.1.1.2.2.1.6.16777283
queues=.1.3.6.1.4.1.14988.1.1.2.2.1.8.16777283
One more thing,
on this page (Which I believe to be a bit dated now) https://www.mikrotik.com/testdocs/ros/2.8/appex/mrtg1.php it suggests that I use the “flow” OID to graph a queue tree.
I am running v6.27 and it does not show me an OID for flow. I have the following options
name
packet-mark
bytes
packets
queues
I have gone for the “bytes” OID. I assume that is the correct OID to graph the amount of traffic currently in the queue.
