Queue tree priorities dont work, slow pages opening, winbox freezing
So i purchased hex lite in order to get my ADSL traffic in order.Iv set up several mangle rules for different traffic types (http, ftp, p2p, radi streams, web pages) and iv set a Queue Tree with separated download and upload and iv set limits and priorities to my likening.At first glance everything seams to work perfect, i can see traffic flowing thru individual queues, and limits iv set for them for download and upload are WORKING.Now problem is, for example, when im downloading some biger files, which goes over http queue(priority 6) which is limited 15m(from my total 18M badnwith), and than i open an web page which has higher priority (4) it opens very slow, loads in 3-4 sec than another 3-4 sec theres spinner on top of chrome as it sitll haven finished fully loading.I dont understand what im doing wrong here, i was thinking if i put pages in higher priority they should open quickly like there’s no downloads going on (downloads should slow down).
Also, as im monitoring traffic my winbox often freezes, stats stop to update, and i cant close app on X, i need to kill it from task manager, i already tried on 4 different pcs same thing happens.I have also checked CPU usage which never crosses 50%.
Using latest Winbox version 3.0rc12 and currently latest OS 6.30rc29 which i tried upgrading from previous release one in hope it would fix the issue.
Here are few pics of my setup, im not sure how to show you full configuration as i didint use scripts mostly but set all from UI.But ether 2 is connected to my ADSL modem and ether 3 goes to switch and the rest of the network.Ports are bridged, and ip firewall is enabled.
EDIT:Support file
https://www.dropbox.com/s/3a8cdd4hc3van5p/supout.rif?dl=0
EDIT:I added supout.rif file
