queue tree
following the docs on:
http://www.mikrotik.com/docs/ros/2.9/root/queue
The examle at the bottom of the page gives an error:
add connection=users-con mark-flow=users action=mark-flow chain=forward
ambiguous input (connection)
no such argument (connection)
Are these commands actually compattable with 2.9? I cannot get queue tree to work right?
In recent 2.9 versions command names have slightly changed to maintain consistency throughout the interface.
add connection-mark=users-con new-packet-mark=users action=mark-packet chain=forward
Thanks you were right. I just assumed that because it was 2.9 docs it would be correct!!
Anyway I got it working untill the system crashed and I cannot login anymore. It’s definatly caused by some bug in the queue tree entrys and when you reboot you lose all settings and cannot restore config :frowning:
Have you tried export and import commands?
No I have not! Does that try to import a config from 2.8 by chance?
no, import issues commands. commands in 2.8 and 2.9 are different.
Hi
I am too running Routeros 2.9beta16 and I am having problem setting up B/W shaping queues.
as sugested in OS 2.9 manual these two commands should have done my work.
[bikrant@MikroTik] ip firewall mangle> add src-address=192.168.0.0/24 action=mark-connection new-connection-mark=server-con chain=prerouting
I don’t see any new-connection-mark match instead there is connection-mark.
[bikrant@MikroTik] ip firewall mangle> add connection-mark=server-con action=mark-packet new-packet-mark=server chain=prerouting
action=mark-packet is not supported. mark-packet action is not listed at all!.
What is the solution? DO i need to upgrade to newer version?
Please suggest.
Bikrant
Yup, you definitely need to upgrade.
thanks It worked as expected. Upgrading OS is really cool :smiley:
