Queued Bytes
I think myself very skillful for being able to que this much data after 1 min of uptime :slight_smile:
Only started happening after upgrade to .38
I think it’s only cosmetic as it still works well
Pretty funny tho :slight_smile:
Check ‘queue simple print stats’ to see the same value in console.
It shows the correct amount for the individual que’s but I cannot see the total (the bit I circled) anywhere.
I’m not worried at all about it, just find it funny :slight_smile:
