with astonishment I noticed that with ROS7.1beta2 it is still not possible to set Queueing with speeds greater than 4294M!!
There is still the old 90s-style 32Bit Integer (2^32=4,294,967,296) limit present.
I cant believe in 2020 they still have not rised that stinkin 32Bit limit…
A software which runs 10G-Ports should be able to control these speeds as well.
@Mikrotik: Please consider allowing speeds greater than 4294M!!
