How i can create a queue and specify the mobile devices using Android or Apple?
i want to find the mobiles based on Hostname on dhcp leases, it is possible?
I’m not a scripting expert, someone else would have to answer that. If the host name has some indication of what the device is, it should be possible. Would be easy to defeat once someone found out though.
Is it possible to assign static DHCP leases via the mac address? The mac address could have a clue as well.
the hostname have that indicator if was an ipad or android device…,static dhcp is possible, but i have almost 700 devices…
Stiil trying with some scripts i found but none of then work.
Hi Is ther any solution for this issue plese?
