Hello
I use dhcp/hotspot, both based on radius. Radius gives attribute RateLimit to dhcp and that creates the queue and cut the bandwidth of that user.
That generally works.
Is there any possibility to have two different MAC address, two different users to operate in the same queue? I mean set the common bandwidth limit to two or more PCs.
Thanks in advance for any ideas
Regards,
Gregor
Hello friend,
I thing is possible, you can create new queue simple for that subnet e.g: xxx.xxx.xxx.0/24 [that's for 24 bits ranges] or as subnet you want
my pppoe, hotspot and dynamic just enought with simple queue
give me more exploring RouterOS
thanks
I don’t understand such English and I’m sure you have’nt understood my question.
Gregor
I think you cannot set one queue for two different HotSpot users.
You can accoplish it, using static queues + mangle rules.
