Queues (Hotspot)
i have a router and i have 3 wlan interfaces, and for every client i have simple queue, so when i set up hotspot in simple queue adds and hs-Wlan queue 0.0.0.0/0 address, so how can i leave queues for everyclients..
does anybody have any advice, please help me because i need it very much..
If you have the same bandwidth limit for all HotSpot clients, you can specify rate-limit for HotSpot profile, so bandwidth limit rule will be added automatically for each client.
If you want to leave current ‘queue simple’ entries, you have to move them above HotSpot dynamic queue.
yes i wanna leave current simple queues, but tell me where i can select hotspot dynamic queue…
its on queue type (hotspot-default)…??\
tell me where can i change it
respect..
When a user loged in via hotspot it may recieive and ip from your ip pool then it is easy go to queue and then add simple queue with Queue type PCQ.
first go add this:
add name="64k" kind=pcq pcq-rate=64000 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=2000
then
add name="Users" target-addresses=192.168.1.0/24 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=8 queue=64k/64k limit-at=0/0 max-limit=0/0 total-queue=default-small disabled=no
it’s work good as i use it in some places.
you can add diffrent configs for 128k, 256k and … like above
my friend, i wanna consult about this job, im using static Ip, and working with macc address and simple queues for each customer..But now i have set up a hotspot, because when a client dont pay to me , i will remove it from ip Bindings, and in hiw homepage it will alert you have to pay…, so tell me can i use that simple queues that i already using..
