Hello
CPU at 50%
I find that when I put a queue on an interface my pings go up a few MS (even when I’m not getting affected by the queue)
Its no big problem, just wondered why?
I was thinking it could just be the extra processing needed
Thanks ![]()
Hello
CPU at 50%
Thanks ![]()
What CPU do you have there? Is it a RouterBoard?
Hello
Yes, a routerboard running at 400Mhz
CPU never shows it working hard tho
Are you sure you’re not maxing out the queue?
Yep, I’m sure.
Its PCQ and the only thing I have running is a ping.
I also got on another PC and teh same thing, only had a ping running.
It works well becuase if I download to fast ping will go to 2000k while other users saty at 10ms
Is this 2.9 or 3.0?
2.9
