Queues Mikrotik does not work
Good afternoon. Personally, I’m a beginner in Mikrotik, and I’m having a hard time doing band control with Queues. I need to control the band per interface. I applied the settings, but the bandwidth control did not work. Can anyone help?
Isn’t the fasttrack enabled?
Try Disable FastTrack in IP>Firewall
Sent from my SM-G950U using Tapatalk
Try Disable filter rule FastTrack in IP>Firewall.
is enabled, should I disable it?
disabled, but continues without limiting
Check there are no fasttracking rules in firewall and then reboot the router. Check there are no connections with “F” mark (means fasttrack). If they are, you need to find still active rule that makes it and disable it.If not, you did something wrong with the queue settings.
I rebooted the firewall, searched for fasttrack connections, and did not find anything. See the configuration below;
Then you did something wrong with the queue.
