Hello everyone,
I need help with my PPPoE Server bandwidth. I make profiles and give each one a specified bandwidth limit. The bandwidth limit didn’t match to what I set when I set up my client router for PPPOE. I then tried using basic queues and the destination IP address, but that didn’t work either. However, when I torch the queue profile and try to speed test, my bandwidth limit does work.
More Details: I have running dhcp server, static and PPPoE set up for my LAN interface
# 2024-03-10 16:13:53 by RouterOS 7.13.3
# software id = ********
# model = RB5009UG+S+
# serial number = ************
add name=LAN_BRIDGE
set [ find default-name=ether1 ] name=eth1-WAN
set [ find default-name=ether2 ] name=eth2-WAN2
/interface wireguard
add comment=back-to-home-vpn listen-port=1007 mtu=1420 name=back-to-home-vpn
/interface bonding
add name=bond_lan slaves=ether5,ether6
add name=LAN
add name=WAN
add name=dhcp_pool ranges=10.10.0.1-10.10.10.0,10.10.10.2-10.10.255.254
add name=pppoe_pool ranges=120.84.50.0/24
add address-pool=dhcp_pool interface=LAN_BRIDGE lease-time=1d name=\
dhcp_server
/ppp profile
set *0 dns-server=8.8.8.8,192.168.111.1 use-encryption=yes
add dns-server=8.8.8.8,1.1.1.1 local-address=120.84.50.1 name=5Mbps \
rate-limit=6M/6M remote-address=pppoe_pool use-encryption=yes
add dns-server=8.8.8.8,1.1.1.1 local-address=120.84.50.1 name=15Mbps \
rate-limit=17M/17M remote-address=pppoe_pool use-encryption=yes
add dns-server=8.8.8.8,1.1.1.1 local-address=120.84.50.1 name=10Mbps \
rate-limit=11M/11M remote-address=pppoe_pool use-encryption=yes
add dns-server=8.8.8.8,1.1.1.1 local-address=120.84.50.1 name=20Mbps \
rate-limit=22M/22M remote-address=pppoe_pool use-encryption=yes
add bridge=LAN_BRIDGE interface=LAN
/interface detect-internet
set detect-interface-list=all
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=bond_lan list=LAN
add interface=eth1-WAN list=WAN
add interface=eth2-WAN2 list=WAN
/interface pppoe-server server
add default-profile=5Mbps disabled=no interface=LAN_BRIDGE \
one-session-per-host=yes service-name=pppoe_server
/interface wireguard peers
add allowed-address=*******************
add address=10.10.10.1/16 interface=LAN_BRIDGE network=10.10.0.0
add address=192.168.50.1/24 interface=LAN_BRIDGE network=192.168.50.0
add address=192.168.100.1/24 interface=LAN_BRIDGE network=192.168.100.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add address=10.10.0.0/16 dns-server=8.8.8.8,1.1.1.1 gateway=10.10.10.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input comment="accept establised,related" \
connection-state=established,related in-interface-list=WAN
add action=drop chain=input connection-state=invalid in-interface-list=WAN
add action=accept chain=input comment="Allow Winbox" dst-port=8291 \
in-interface-list=WAN protocol=tcp src-port=8291
add action=accept chain=input comment="allow SSH" dst-port=22 \
add action=drop chain=input comment="block everything else" \
add action=fasttrack-connection chain=forward comment=\
"fast-track for established,related" connection-state=established,related \
hw-offload=yes
add action=accept chain=forward comment="accept established,related" \
"drop access to clients behind NAT from WAN" connection-nat-state=!dstnat \
/ip firewall mangle
/ip firewall raw
/ip service
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=ppp1 profile=5Mbps service=pppoe
/system clock
set time-zone-name=********
/system identity
set name=***********************
/system note
set show-at-login=no
/tool bandwidth-server
set authenticate=no
/tool mac-server
/tool mac-server mac-winbox
