Hi Forum,
I’ve set up a transparent bridge of sorts on a CCR 1036.
THe 2 incoming interfaces are vlans, different tags of course. I add both these vlans to bridge
Bridge settings are set to use IP Firewall, and fast path off
I can block the traffic in ip firewall filter, and I can mark packets in ip firewall mangle successfully.
What I cant seem to do is set up simple queue to capture the traffic. I am using mangle to mark the packets I wanted limited and i’ve tried setting the target to the bridge interface and to either of the vlan interfaces (the bridge port members).
/queue simple
add name=test packet-marks=TESTPACKET target=Bridge
I’ve set it up as simple as possible just to see the traffic hitting the queue in the statistics (sending many ICMP packets atm) but it just never seems to match.
Any thoughts? Does the traffic not actually hit that bridge interface? I thought by turning off fast path and turning on ip firewall it forces all traffic in to it, I can successfully see the traffic on mangle and filter just simple queue doesnt seem to want to help.
