Queues problem with upgrade to Ros V3.30
We have noticed on the RB’s that we have upgraded from v3.28 to V3.30 that the packet marker gets dropped from the queue tree’s when we run the following script.
:foreach i in [/queue tree find packet-mark=“Bulk”] do={
/queue tree set $i max-limit=512K limit-at=512K }
This has been working for us all the way until now.
We got a fix for it by :
add name=start_limit policy=reboot,read,write,test,winbox source=“:foreach i in [/queue tree find packet-mark="Bulk"]
do={/queue tree set $i pac="Bulk" max-limit=512K limit-at=512K }”
We don’t want to roll out the upgrade to all the sites at this stage as not everyone would follow the change of script and it would just make a mess again.
Do you know off this problem, and would you have a fix with the new release?
Thank you,
Russian
i have the same problem on x86 boxe queue tree isnt woeking as it did in 3.28
so i just downgraded fro 3.30 back to 3.28 easyer at this point in time
Would you have a fix for this in then new release?
We also find that on some of our sites we get 100% CPU usage with 3.28 and 3.30 with routing-test enabled, the we revert back to routing package. This is on RB433/ah and x86 boxes.
You have any fixes for this by anychance?
If your current version works, do not upgrade.
What for anyway ? Wait until the bugs are fixed - let other people take the pain.
