Queues stop working after a while
Hi, everyone.
We’ve a RouterOS v5.8 running on a Intel PC. CPU has 4 cores. It works fine, but suddenly some queues stop working. Rebooting is the only way it starts working OK again.
I don’t if it has to be but I’ve noticed that most of IRQs are assigned to just one of CPU’s cores.
Thanks for your time. We’ll appreciate your help.
I read a post here that said “Contacted support, they said there are issues with multi-core systems and v5. Best bet is either to downgrade to 4.17 or wait for v6.” http://forum.mikrotik.com/t/pc-x86-v4-3-to-5-18/57796/1
Your problem could be related to that, as you have a 4-core system.
Thanks jandafields. We’ll wait for v6 and the we’ll see.
6.0 RC3 is out. You might want to try that one now, so you can tell support if it still doesn’t work properly.
