Simple queue per user shows the exact data flow, but queue tree shows false data!
anything i should do to fix this problem?
thanks,
i have something similar to this:
http://forum.mikrotik.com/t/bandwidth-control-problem/22749/1
thanks,
I GET SOMTHING TO THIS ALSO
SECET FOR PPPOE CONNECTION WITH 512/512
BUT THAT USER CAN DOWNLOAD AT 1024 AS IT TELLS ME IN WINDOX AND QUES STAYS GREEN
NEVERLIMITS
You can’t catch the same traffic with simple queues and queue tree at the same time. If traffic is queued with simple queue then it will not reach queue tree.
ok, that makes sense, but that way i won’t be able to see each user’s true bandwidth as a queue.
ty,
