Quick hotspot question
If you have several bridged interfaces, can one of those interfaces be chosen as the hotspot interface?
Just tried this and the hotspot is not doing anything.
No… Slave interfaces shouldn’t have IP addresses, any DHCP/hotspot servers, etc. You should set them on the bridge interface (master).
Understood. Thanks.
Can you elaborate more why you can’t or you shouldn’t do this?
I have 2 SSID, the first one is the primary wireless interface and the second is a virtual IP.
The first SSID is bridged on the lan ports (with the same IP block) and the second wireless (virtualAP) is not bridged but slave to the master wireless interface. I have setup the IP hotspot in this interface. I also have an IP assigned to it. Is this wrong?
