Quick Mount Pro Dimensions
I have to buy / make some U-Bolts for the Quick Mount pro, https://mikrotik.com/product/QMP
Have a client who have mounted this on a pole on the roof with cable ties, if anyone has the dimensions or a URL where I can get this it will be appreciated.
I need the diameter for the holes and distance between the centre of the holes.
Bump, Any drill hole template drawings please?
Else I have to get up on the roof, disconnect everything, take measurements, go and buy / make a u-bolts, go back and install again and all this time client will be down.
https://forum.mikrotik.com/viewtopic.php?f=2&t=139943
