*) api - use the same syntax for property values as is used in ‘print detail’
output;
Could you give a before and after example of where it makes a difference?
And on a related note,
*) console - show internal numbers in the form returned by ‘find’ (like *9A0F)
instead of ~(unknown)~ when configuration refers to
deleted items. This change also applies to API.
Wait… How could you possibly ever “find” deleted items? If they’re deleted, wouldn’t they just not be included in the output? I can understand if you had a “print”, and there was a property who’s value refers to another item that happens to be deleted, but no… This is “find”… It’s done against the actual existing items, and only returns the actual items’ IDs. An ID should not be included if the item itself is deleted, and whether or not that item has a property referring to another item should be irrelevant, except in a “where” match… And last I checked, “find” does not support API queries (though it should).
