Good morning I want to ask a question, if someone helps me I would be grateful.
I have a mikrotik 4011 without a wireless network, I have my ISP router in bridge mode and then my 4011 in bridge mode and then my normal mesh routers.
The question is when I configure 4011 on bridge, some router options are disabled, such as firewall, VPN tunnels.
Or do all the router functions remain active, only the way I get IP from the ISP router changes?
Quote from MikroTik Wiki:
Bridge mode adds all interfaces to the bridge allowing to forward Layer2 packets (acts as a hub/switch).
Hence, it won’t be able to work as a router because it removes default configuration (atleast I think so for the last part, haven’t used it myself very often)
