I have noticed strange issue in Quick Set that confused me.
I have MikroTik RB750GL with RouterOS 6.25
- ether5 - connected to WAN1
- ether4(port disabled) - connected to WAN2
- ether3(port disabled) - not used
- ether2 - connected to LAN
- ether1(port disabled) - not used(previous WAN1)
IP - DHCP client - I have there 3 DHCP clients
- On ether1 - DHCP client disabled(historically, default config)
- On ether4 - DHCP client disabled(I enable it after enabling ether4 to access WAN2)
- On ether5 - DHCP client enabled and is getting IP for WAN1
Up to here it is OK and everything works. But when I go to Quick Set with this settings it show:
Address Acquisition: Static
IP Address: 0.0.0.0
Netmask: 255.0.0.0 (/8)
And it all looks like my DHCP setting is broken. Actually nothing is broken everything works.
- I think that Quick Set does not recognize the DHCP in use on ether5. It propably does not count with two previous disabled DHCPs on ether1 and ether4.
See attached screenshot
