The Quick Set (v6.35 for MikroTik RB951G-2HND) enables fast set up for home and guest network, but I do not see two network list etc as described in links above. Is the guest network isolated from the home network when using Quick Set? And how?
There are manuals available how to set up a separate wireless home and guest network. It involves setting up two networks (e.g. 192.168.1.0/24 for home and 192.168.2.0 for guest) and more (setting up the DHCP, firewall rules, etc), see for example:
https://www.geleijn.nl/2014/guest-network-mikrotik-router/
http://blog.codexploit.si/2015/12/mikrotik-guest-wi-fi.html
However when using Quick Set I only see that in Brigde (tab Ports) that wlan2 (guest) is disabled. Is that enough to make sure guest and home networks are separated? Do not see two networks etc. as described in other manuals.
This question had been asked before (http://forum.mikrotik.com/t/winbox-6-15-quick-set/79076/1), unfortunately without any answer.
