hi i’m trying to make a vpn to play with friends.
i have used quick set to make vpn. but just me can login in vpn. others friend can’t join.
how i can enable the vpn to all join?
thank you.
RouterMode:
- WAN port is protected by firewall and enabled DHCP client
- Wireless and Ethernet interfaces (except WAN port ether1)
are part of LAN bridge
wlan1 Configuration:
mode: ap-bridge;
band: 2ghz-b/g/n;
tx-chains: 0;1;
rx-chains: 0;1;
ht-extension: 20/40mhz-Ce;
LAN Configuration:
IP address 192.168.88.1/24 is set on bridge (LAN port)
DHCP Server: enabled;
WAN (gateway) Configuration:
gateway: ether1 ;
ip4 firewall: enabled;
NAT: enabled;
DHCP Client: enabled;
DNS: enabled;
