Quick Typing - autocomplete in console v7.3.1
Today migrated from v6 to v7. Double tab key autocomplete works in v6, but not in v7. This time I’ve red the documentation:
If you’ve typed just the common part, pressing the tab key once has no effect. However, pressing it for the second time shows all possible completions in compact form:
Pressing it for the second time is OK on v6, but not in v7.3.1. Instead od pressing twice i have to press and keep tab key down for more that 1-2 seconds.
/system/[TAB] is OK - shows all possibilities
/system/de[TAB][TAB] is OK on v6, doesn’t work on v7 (two possibilities starts with “de”)
/system/def[TAB] is OK completes the only one possibilities
Can anyone confirm? I’ve tried with Winbox and Putty SSH.
It is a known bug, and is registered in our bug tracker.
