QuickMount Pro and NetMetal5?
Hello MikroTik Gurus,
Can anyone confirm if the NetMetal5 (https://routerboard.com/RB921UAGS-5SHPacD-NM) can be attached to the QuickMount Pro mount (https://routerboard.com/QMP)?
The info for the QuickMount Pro info says “You can use the quickMOUNT pro with any pole mountable device or MikroTik’s small mounting clip with weight less than 1.5 kg.” The NetMetal5 is pole mountable, but, as an owner of a NetMetal5, I don’t see how the two can be attached based on the pictures I’ve found.
The bigger Question is, Why you Need an allign able mount for your Netmetal?
I’m using a NetMetal5 in a home environment with antennas mounted directly on it. I’ve built a mini-mast indoors to attach it to, but using a pipe clamp alone doesn’t make it very easy to make adjustments. The QuickMount Pro is pretty cheap and would make it easy for me to make adjustments.
Until WAP AC is on the market there is no need for using netmetal but it is your choice.
Quickmount comes with 2 mount adapter one for Sxt and one is like a pole
